我们购买了ROC-RK3568-PC的开发板,参考开发板自己做了板子; 按照SDK编译出来的IMAGE,在开发板上能够正常执行,但是开发板无法完成KERNEL初始化,始终会卡住,仔细跟踪后,LOG信息如下,想请教下:具体的原因是什么?或者有什么解决方法? U-Boot 2017.09-g912f242c30 #huangjf (Sep 13 2021 - 18:08:18 +0800) Model: Firefly RK3568 Board PreSerial: 2, raw, 0xfe660000 DRAM: 4 GiB Sysmem: init Relocation Offset: ed35a000 Relocation fdt: eb9f88b0 - eb9fecd8 CR: M/C/I Using default environment dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 0 MMC0: HS200, 200Mhz PartType: EFI boot mode: loader FIT: no signed, no conf required DTB: rk-kernel.dtb HASH(c): OK I2c0 speed: 100000Hz PMIC: RK8090 (on=0x10, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK Could not find baseparameter partition Model: Firefly RK3568-ROC-PC HDMI (Linux) enter Rockusb! Rockchip UBOOT DRM driver version: v1.0.1 CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 780000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 500000 KHz aclk_top_low 400000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000 RKUSB: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x1d1f000 -DDR Version V1.11 20211103 In ddrconfig:15 DDR4, 324MHz BW=32 Col=10 Bk=4 BG=2 CS0 Row=17 CS=1 Die BW=16 Size=4096MB tdqss: cs0 dqs0: 96ps, dqs1: 72ps, dqs2: 0ps, dqs3: -24ps, change to: 324MHz clk skew:0x79 PHY drv:clk:37,ca:37,DQ:37,odt:0 vrefinner:50%, vrefout:50% dram drv:34,odt:0 change to: 528MHz clk skew:0x79 PHY drv:clk:37,ca:37,DQ:37,odt:139 vrefinner:50%, vrefout:61% dram drv:34,odt:120 change to: 780MHz clk skew:0x79 PHY drv:clk:37,ca:37,DQ:37,odt:139 vrefinner:50%, vrefout:61% dram drv:34,odt:120 change to: 1560MHz(final freq) clk skew:0x79 PHY drv:clk:37,ca:37,DQ:37,odt:139 vrefinner:50%, vrefout:61% dram drv:34,odt:120 cs 0: the read training result: DQS0:0x39, DQS1:0x32, DQS2:0x33, DQS3:0x35, min : 0xf 0xb 0xe 0xb 0x1 0x5 0x4 0x2 , 0x7 0xb 0x1 0x8 0x4 0xb 0x8 0xb ,
mid :0x29 0x27 0x28 0x24 0x1c 0x1e 0x1e 0x1d ,0x1f 0x23 0x17 0x21 0x1c 0x23 0x21 0x22 ,
max :0x43 0x43 0x43 0x3e 0x37 0x38 0x38 0x38 ,0x38 0x3b 0x2d 0x3a 0x35 0x3b 0x3b 0x3a ,
range:0x34 0x38 0x35 0x33 0x36 0x33 0x34 0x36 ,0x31 0x30 0x2c 0x32 0x31 0x30 0x33 0x2f ,
the write training result: DQS0:0x8c, DQS1:0x87, DQS2:0x79, DQS3:0x75, min :0x78 0x78 0x7a 0x79 0x6b 0x6b 0x6e 0x6e 0x76 ,0x71 0x73 0x6b 0x74 0x72 0x74 0x74 0x72 0x6a ,
mid :0x91 0x91 0x92 0x8f 0x81 0x83 0x87 0x85 0x8e ,0x89 0x8b 0x7e 0x89 0x88 0x8a 0x89 0x8a 0x80 ,
max :0xab 0xab 0xab 0xa6 0x98 0x9b 0xa0 0x9c 0xa6 ,0xa1 0xa3 0x92 0x9e 0x9e 0xa1 0x9e 0xa3 0x96 ,
range:0x33 0x33 0x31 0x2d 0x2d 0x30 0x32 0x2e 0x30 ,0x30 0x30 0x27 0x2a 0x2c 0x2d 0x2a 0x31 0x2c ,
out U-Boot SPL board init U-Boot SPL 2017.09-g5961c0c398 #zsm (Jan 10 2022 - 11:58:41) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 MMC error: The cmd index is 1, ret is -110 Card did not respond to voltage select! mmc_init: -95, time 10 spl: mmc init failed with error: -95 Trying to boot from MMC1 Magic is incorrect. Error validating A/B metadata from disk. Resetting and writing new A/B metadata to disk. SPL: A/B-slot: _a, successful: 0, tries-remain: 7 Verified-boot: 0Checking atf-1 0x00040000 ... sha256(fe4f274c06...) + OKChecking uboot 0x00a00000 ... sha256(a42b439b91...) + OKChecking fdt 0x00b22628 ... sha256(30938731de...) + OKChecking atf-2 0x00068000 ... sha256(8d44036095...) + OKChecking atf-3 0xfdcd0000 ... sha256(e410275b51...) + OKChecking atf-4 0xfdcc9000 ... sha256(990c53fc01...) + OKChecking atf-5 0x00066000 ... sha256(315a4195a9...) + OKChecking optee 0x08400000 ... sha256(5a22c90dfc...) + OKJumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 238.312 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-181-gc9a647cae:cl NOTICE: BL31: Built : 10:55:41, Oct 18 2021 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 I/TC: I/TC: OP-TEE version: 3.13.0-515-g7b4275734 #hisping.lin (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Wed Aug 4 07:11:39 UTC 2021 aarch64 I/TC: Primary CPU initializing I/TC: Primary CPU switching to normal world boot INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09-g5961c0c398 #zsm (Jan 10 2022 - 11:58:41 +0800) Model: Firefly RK3568 Board PreSerial: 2, raw, 0xfe660000 DRAM: 4 GiB Sysmem: init Relocation Offset: ed356000 Relocation fdt: eb9f8310 - eb9fece8 CR: M/C/I Using default environment dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 0 MMC0: HS200, 200Mhz PartType: EFI boot mode: recovery (misc) FIT: no signed, no conf required DTB: rk-kernel.dtb HASH(c): OK I2c0 speed: 100000Hz PMIC: RK8090 (on=0x10, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK Could not find baseparameter partition Model: Firefly RK3568-ROC-PC HDMI (Linux) Rockchip UBOOT DRM driver version: v1.0.1 VOP have 1 active VP vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4 vp1 have layer nr:0[], primary plane: 0 vp2 have layer nr:0[], primary plane: 0 hdmi@fe0a0000 disconnected CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 780000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 500000 KHz aclk_top_low 400000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000 Hit key to stop autoboot('CTRL+C'): 0 Booting FIT Image at 0xe9a3d300 with size 0x01dba000Fdt Ramdisk skip relocation Loading kernel from FIT Image at e9a3d300 ...Using 'conf' configuration optee api revision: 2.0 TEEC: Waring: Could not find security partition Verified-boot: 0Trying 'kernel' kernel subimage
Verifying Hash Integrity ... sha256+ OK Loading ramdisk from FIT Image at e9a3d300 ...Using 'conf' configuration Trying 'ramdisk' ramdisk subimage
Verifying Hash Integrity ... sha256+ OK Loading ramdisk from 0xeb15eb00 to 0x0a200000 Loading fdt from FIT Image at e9a3d300 ...Using 'conf' configuration Trying 'fdt' fdt subimage
Verifying Hash Integrity ... sha256+ OK Loading fdt from 0x0a100000 to 0x0a100000 Booting using the fdt blob at 0x0a100000 Loading Kernel Image from 0xe9a5e100 to 0x00280000 ... OK kernel loaded at 0x00280000, end = 0x01980808 'reserved-memory' ramoops@110000: addr=110000 size=f0000 Using Device Tree in place at 000000000a100000, end 000000000a123437 vp0, plane_mask:0x3f, primary-id:4, curser-id:-1 vp1, plane_mask:0x0, primary-id:0, curser-id:-1 vp2, plane_mask:0x0, primary-id:0, curser-id:-1 Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x09400000 - 0xf0000000 (size: 0xe6c00000) Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000) Total: 834.833 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 4.19.206 (zsm@zsm-virtual-machine) (firefly: c0c173e0214eeaa0d057599d2f1c6a83213483b1) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05) 2.27.0.20161019) #4 SMP Mon Jan 10 11:58:48 CST 2022 [ 0.000000] Machine model: Firefly RK3568-ROC-PC HDMI (Linux) [ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '') [ 0.000000] bootconsole [uart8250] enabled [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 23 pages/cpu s54184 r8192 d31832 u94208 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656 [ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=sdhci@fe310000 ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0xe9f00000-0xedf00000] (64MB) [ 0.000000] Memory: 3971388K/4175872K available (14718K kernel code, 1986K rwdata, 5220K rodata, 1600K init, 586K bss, 188100K reserved, 16384K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 53255 entries in 209 pages [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] ITS [mem 0xfd440000-0xfd45ffff] [ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices [url=home.php?mod=space&uid=1086896]@210000[/url] (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @220000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x0000000000230000 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] CPU0: using LPI pending table @0x0000000000240000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x510 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.002238] Console: colour dummy device 80x25 [ 0.002700] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 0.003664] pid_max: default: 32768 minimum: 301 [ 0.004262] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.004910] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.007398] ASID allocator initialised with 32768 entries [ 0.008078] rcu: Hierarchical SRCU implementation. [ 0.011459] Platform MSI: interrupt-controller@fd440000 domain created [ 0.012644] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created [ 0.014258] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot [ 0.016190] Detected VIPT I-cache on CPU1 [ 0.016231] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.016284] CPU1: using LPI pending table @0x0000000000250000 [ 0.016340] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.017950] Detected VIPT I-cache on CPU2 [ 0.017988] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.018040] CPU2: using LPI pending table @0x0000000000260000 [ 0.018087] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.019658] Detected VIPT I-cache on CPU3 [ 0.019696] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.019755] CPU3: using LPI pending table @0x0000000000270000 [ 0.019801] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.019940] smp: Brought up 1 node, 4 CPUs [ 0.026903] SMP: Total of 4 processors activated. [ 0.027346] CPU features: detected: GIC system register CPU interface [ 0.027944] CPU features: detected: Privileged Access Never [ 0.028467] CPU features: detected: LSE atomic instructions [ 0.028989] CPU features: detected: User Access Override [ 0.029489] CPU features: detected: 32-bit EL0 Support [ 0.029972] CPU features: detected: RAS Extension Support [ 0.030689] CPU: All CPU(s) started at EL2 [ 0.031106] alternatives: patching kernel code [ 0.038546] devtmpfs: initialized [ 0.069074] Registered cp15_barrier emulation handler [ 0.069569] Registered setend emulation handler [ 0.070352] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 0.071318] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.072678] pinctrl core: initialized pinctrl subsystem [ 0.074280] NET: Registered protocol family 16 [ 0.079900] cpuidle: using governor menu [ 0.080308] Registered FIQ tty driver [ 0.081606] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.083725] DMA: preallocated 1024 KiB pool for atomic allocations [ 0.088318] console [pstore-1] enabled [ 0.088675] pstore: Registered ramoops as persistent store backend [ 0.089258] ramoops: attached 0xf0000@0x110000, ecc: 0/0 [ 0.129886] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio) [ 0.131196] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio) [ 0.132522] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio) [ 0.133817] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio) [ 0.135117] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio) [ 0.135865] rockchip-pinctrl pinctrl: probed pinctrl [ 0.154434] cryptd: max_cpu_qlen set to 1000 [[ 0.156830] console [ttyFIQ0] enabled
[ 0.157516] bootconsole [uart8250] disabled [ 0.157516] bootconsole [uart8250] disabled [ 0.158201] Registered fiq debugger ttyFIQ0 [ 0.159282] vcc3v3_sys: supplied by dc_12v [ 0.159783] vcc5v0_sys: supplied by dc_12v [ 0.161563] vcc2v5-sys: supplied by vcc3v3_sys [ 0.162035] pcie30_avdd0v9: supplied by vcc3v3_sys [ 0.162536] pcie30_avdd1v8: supplied by vcc3v3_sys [ 0.163023] vcc3v3_bu: supplied by vcc5v0_sys [ 0.166984] rk_iommu fde4b000.iommu: version = 2 [ 0.167759] rk_iommu fdea0800.iommu: version = 2 [ 0.168209] rk_iommu fded0480.iommu: version = 2 [ 0.168593] rk_iommu fdee0800.iommu: version = 2 [ 0.168959] rk_iommu fdef0800.iommu: version = 2 [ 0.169324] rk_iommu fdf40f00.iommu: version = 2 [ 0.169763] rk_iommu fdf80800.iommu: version = 2 [ 0.170145] rk_iommu fdff1a00.iommu: version = 2 [ 0.170493] rk_iommu fe043e00.iommu: version = 2 [ 0.171619] SCSI subsystem initialized [ 0.171960] usbcore: registered new interface driver usbfs [ 0.172051] usbcore: registered new interface driver hub [ 0.172135] usbcore: registered new device driver usb [ 0.172262] media: Linux media interface: v0.10 [ 0.172329] videodev: Linux video capture interface: v2.00 [ 0.172459] pps_core: LinuxPPS API ver. 1 registered [ 0.172486] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.172537] PTP clock support registered [ 0.172960] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 0.176047] Advanced Linux Sound Architecture Driver Initialized. [ 0.176658] Bluetooth: Core ver 2.22 [ 0.176735] NET: Registered protocol family 31 [ 0.176762] Bluetooth: HCI device and connection manager initialized [ 0.176792] Bluetooth: HCI socket layer initialized [ 0.176819] Bluetooth: L2CAP socket layer initialized [ 0.176885] Bluetooth: SCO socket layer initialized [ 0.177453] rockchip-cpuinfo cpuinfo: SoC : 35682000 [ 0.177485] rockchip-cpuinfo cpuinfo: Serial : 8629c8fd777938f1 [ 0.179035] clocksource: Switched to clocksource arch_sys_counter [ 0.280221] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.280630] NET: Registered protocol family 2 [ 0.280942] IP idents hash table entries: 65536 (order: 7, 524288 bytes) [ 0.283298] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes) [ 0.283423] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 0.283749] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 0.284772] TCP: Hash tables configured (established 32768 bind 32768) [ 0.285021] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 0.285270] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 0.285806] NET: Registered protocol family 1 [ 0.286552] RPC: Registered named UNIX socket transport module. [ 0.286580] RPC: Registered udp transport module. [ 0.286599] RPC: Registered tcp transport module. [ 0.286621] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.288493] Trying to unpack rootfs image as initramfs... [ 0.679489] Freeing initrd memory: 6752K [ 0.681229] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.684182] Initialise system trusted keyrings [ 0.684446] workingset: timestamp_bits=61 max_order=20 bucket_order=0 [ 0.693115] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.694184] NFS: Registering the id_resolver key type [ 0.694237] Key type id_resolver registered [ 0.694252] Key type id_legacy registered [ 0.694309] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 0.694605] fuse init (API version 7.27) [ 0.695223] SGI XFS with security attributes, no debug enabled [ 0.698806] NET: Registered protocol family 38 [ 0.698861] Key type asymmetric registered [ 0.698878] Asymmetric key parser 'x509' registered [ 0.698938] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.698965] io scheduler noop registered [ 0.698986] io scheduler deadline registered [ 0.699249] io scheduler cfq registered (default) [ 0.699280] io scheduler mq-deadline registered [ 0.699301] io scheduler kyber registered [ 0.700747] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully! [ 0.700958] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully! [ 0.704595] phy phy-fe8b0000.usb2-phy.0: Linked as a consumer to regulator.4 [ 0.704833] phy phy-fe8b0000.usb2-phy.1: Linked as a consumer to regulator.4 [ 0.705023] phy phy-fe8b0000.usb2-phy.1: No vbus specified for otg port [ 0.715521] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.15 [ 0.716120] rochchip_p3phy_init: lock failed 0x6890000, check input refclk and power supply [ 0.716162] phy phy-fe8c0000.phy.5: phy init failed --> -110 [ 0.716189] rk-pcie 3c0800000.pcie: fail to init phy, err -110 [ 0.716211] rk-pcie 3c0800000.pcie: phy init failed [ 0.716217] mpp_service mpp-srv: d47e486b19bd author: Yandong Lin 2021-11-04 video: rockchip: mpp: use dma-buf-cache func [ 0.716224] mpp_service mpp-srv: probe start [ 0.717475] iommu: Adding device fdf40000.rkvenc to group 5 [ 0.717531] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu [ 0.717804] mpp_rkvenc fdf40000.rkvenc: probing start [ 0.718411] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry [ 0.718441] rkvenc_init:1199: failed to add venc devfreq [ 0.718927] mpp_rkvenc fdf40000.rkvenc: probing finish [ 0.720482] iommu: Adding device fdea0400.vdpu to group 1 [ 0.720547] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu [ 0.720792] mpp_vdpu2 fdea0400.vdpu: probe device [ 0.721574] mpp_vdpu2 fdea0400.vdpu: probing finish [ 0.722334] iommu: Adding device fdee0000.vepu to group 3 [ 0.722431] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu [ 0.722695] mpp_vepu2 fdee0000.vepu: probe device [ 0.723417] mpp_vepu2 fdee0000.vepu: probing finish [ 0.724166] iommu: Adding device fdef0000.iep to group 4 [ 0.724220] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu [ 0.724427] mpp-iep2 fdef0000.iep: probe device [ 0.725060] mpp-iep2 fdef0000.iep: allocate roi buffer failed [ 0.725296] mpp-iep2 fdef0000.iep: probing finish [ 0.726028] iommu: Adding device fded0000.jpegd to group 2 [ 0.726084] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu [ 0.726298] mpp_jpgdec fded0000.jpegd: probe device [ 0.727043] mpp_jpgdec fded0000.jpegd: probing finish [ 0.727784] iommu: Adding device fdf80200.rkvdec to group 6 [ 0.727825] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu [ 0.728165] mpp_rkvdec2 fdf80200.rkvdec: probing start [ 0.728378] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected [ 0.728843] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found! [ 0.728873] rkvdec2_init:661: No niu aclk reset resource define [ 0.728901] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found! [ 0.728923] rkvdec2_init:664: No niu hclk reset resource define [ 0.729210] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000 [ 0.729241] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000 [ 0.729266] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056 [ 0.729287] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536 [ 0.729306] mpp_rkvdec2 fdf80200.rkvdec: min_width 512 [ 0.729383] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish [ 0.729494] mpp_rkvdec2 fdf80200.rkvdec: probing finish [ 0.729965] mpp_service mpp-srv: probe success [ 0.737706] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330 [ 0.737751] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.741005] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330 [ 0.741045] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.742934] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 0.744307] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.745428] fe670000.serial: ttyS3 at MMIO 0xfe670000 (irq = 66, base_baud = 1500000) is a 16550A [ 0.746363] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 67, base_baud = 1500000) is a 16550A [ 0.747249] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 68, base_baud = 1500000) is a 16550A [ 0.751010] random: fast init done [ 0.751360] random: crng init done [ 0.751761] iommu: Adding device fe040000.vop to group 8 [ 0.751821] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu [ 0.758418] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop [ 0.760302] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi [ 0.763185] rockchip-drm display-subsystem: dmc is disabled [ 0.763560] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4 [ 0.763604] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1 [ 0.763640] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1 [ 0.763921] [drm] unsupported AFBC format[3432564e] [ 0.764007] [drm] failed to init overlay plane Cluster0-win1 [ 0.764094] [drm] failed to init overlay plane Cluster1-win1 [ 0.764252] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8008fba4d8) [ 0.764516] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 0.765243] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 0.766120] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8008fbdff0) [ 0.766157] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.766179] [drm] No driver support for vblank timestamp query. [ 0.766478] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes [ 0.766574] rockchip-drm display-subsystem: can't not find any loader display [ 0.766610] rockchip-drm display-subsystem: failed to show loader logo [ 0.766663] [drm] Cannot find any crtc or sizes [ 0.767719] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0 [ 0.775212] mali fde60000.gpu: Kernel DDK version g7p1-01bet0 [ 0.775384] mali fde60000.gpu: Device initialization Deferred [ 0.775535] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 0.776603] brd: module loaded [ 0.786312] loop: module loaded [ 0.786955] zram: Added device: zram0 [ 0.787147] lkdtm: No crash points registered, enable through debugfs [ 0.788966] ahci fc800000.sata: forcing port_map 0x0 -> 0x1 [ 0.789098] ahci fc800000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode [ 0.789135] ahci fc800000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst [ 0.789175] ahci fc800000.sata: port 0 is not capable of FBS [ 0.790425] scsi host0: ahci [ 0.790929] ata1: SATA max UDMA/133 mmio [mem 0xfc800000-0xfc800fff] port 0x100 i
[ 0.941023] rk_gmac-dwmac fe2a0000.ethernet: no regulator found [ 0.941070] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (input). [ 0.941091] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c). [ 0.941107] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f). [ 0.941130] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no). [ 0.941220] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY [ 0.946260] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII [ 0.946595] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 0.946627] rk_gmac-dwmac fe2a0000.ethernet: DWMAC4/5 [ 0.946655] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported [ 0.946682] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported [ 0.946706] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported [ 0.946728] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported [ 0.946790] rk_gmac-dwmac fe2a0000.ethernet: TSO supported [ 0.946808] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 0.946826] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled [ 1.079073] libphy: stmmac: probed [ 1.084142] usbcore: registered new interface driver rndis_wlan [ 1.084250] usbcore: registered new interface driver rtl8150 [ 1.084334] usbcore: registered new interface driver r8152 [ 1.084416] usbcore: registered new interface driver asix [ 1.084505] usbcore: registered new interface driver ax88179_178a [ 1.084584] usbcore: registered new interface driver cdc_ether [ 1.084672] usbcore: registered new interface driver rndis_host [ 1.084768] usbcore: registered new interface driver cdc_ncm [ 1.084857] usbcore: registered new interface driver qmi_wwan_q [ 1.084938] usbcore: registered new interface driver qmi_wwan [ 1.085015] usbcore: registered new interface driver cdc_mbim [ 1.086661] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2 [ 1.088060] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2 [ 1.091126] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.091172] ehci-pci: EHCI PCI platform driver [ 1.091268] ehci-platform: EHCI generic platform driver [ 1.093636] ehci-platform fd800000.usb: EHCI Host Controller [ 1.093907] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1 [ 1.094416] ehci-platform fd800000.usb: irq 12, io mem 0xfd800000 [ 1.102439] ata1: SATA link down (SStatus 0 SControl 300) [ 1.105728] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [ 1.106081] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 1.106113] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.106143] usb usb1: Product: EHCI Host Controller [ 1.106168] usb usb1: Manufacturer: Linux 4.19.206 ehci_hcd [ 1.106192] usb usb1: SerialNumber: fd800000.usb [ 1.106880] hub 1-0:1.0: USB hub found [ 1.106956] hub 1-0:1.0: 1 port detected [ 1.109779] ehci-platform fd880000.usb: EHCI Host Controller [ 1.110051] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2 [ 1.110500] ehci-platform fd880000.usb: irq 14, io mem 0xfd880000 [ 1.122414] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [ 1.122734] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 1.122766] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.122793] usb usb2: Product: EHCI Host Controller [ 1.122818] usb usb2: Manufacturer: Linux 4.19.206 ehci_hcd [ 1.122840] usb usb2: SerialNumber: fd880000.usb [ 1.123489] hub 2-0:1.0: USB hub found [ 1.123572] hub 2-0:1.0: 1 port detected [ 1.124661] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.124724] ohci-platform: OHCI generic platform driver [ 1.125046] ohci-platform fd840000.usb: Generic Platform OHCI controller [ 1.125321] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3 [ 1.125613] ohci-platform fd840000.usb: irq 13, io mem 0xfd840000 [ 1.183331] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19 [ 1.183365] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.183383] usb usb3: Product: Generic Platform OHCI controller [ 1.183399] usb usb3: Manufacturer: Linux 4.19.206 ohci_hcd [ 1.183412] usb usb3: SerialNumber: fd840000.usb [ 1.184086] hub 3-0:1.0: USB hub found [ 1.184162] hub 3-0:1.0: 1 port detected [ 1.184898] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [ 1.185179] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 4 [ 1.185455] ohci-platform fd8c0000.usb: irq 15, io mem 0xfd8c0000 [ 1.243328] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19 [ 1.243363] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.243381] usb usb4: Product: Generic Platform OHCI controller [ 1.243397] usb usb4: Manufacturer: Linux 4.19.206 ohci_hcd [ 1.243411] usb usb4: SerialNumber: fd8c0000.usb [ 1.244065] hub 4-0:1.0: USB hub found [ 1.244139] hub 4-0:1.0: 1 port detected [ 1.246413] usbcore: registered new interface driver cdc_acm [ 1.246443] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.246549] usbcore: registered new interface driver cdc_wdm [ 1.246849] usbcore: registered new interface driver uas [ 1.247027] usbcore: registered new interface driver usb-storage [ 1.247184] usbcore: registered new interface driver usbserial_generic [ 1.247258] usbserial: USB Serial support registered for generic [ 1.247336] usbcore: registered new interface driver cp210x [ 1.247395] usbserial: USB Serial support registered for cp210x [ 1.247520] usbcore: registered new interface driver ftdi_sio [ 1.247563] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.247831] usbcore: registered new interface driver keyspan [ 1.247891] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 1.247944] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 1.247998] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 1.248049] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 1.248139] usbcore: registered new interface driver option [ 1.248196] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.248543] usbcore: registered new interface driver oti6858 [ 1.248599] usbserial: USB Serial support registered for oti6858 [ 1.248683] usbcore: registered new interface driver pl2303 [ 1.248739] usbserial: USB Serial support registered for pl2303 [ 1.248844] usbcore: registered new interface driver qcserial [ 1.248903] usbserial: USB Serial support registered for Qualcomm USB modem [ 1.249062] usbcore: registered new interface driver sierra [ 1.249125] usbserial: USB Serial support registered for Sierra USB modem [ 1.250935] usbcore: registered new interface driver usbtouchscreen [ 1.251004] ============ himax_hx83102_init 1742 jjlook ========== [ 1.251030] ============ himax_hx83102_probe 1725 jjlook ========== [ 1.251130] cyttsp5_loader_init: Parade TTSP FW Loader Driver (Built TTDA.03.08.874312) rc=0 [ 1.251158] cyttsp5_device_access_init: Parade TTSP Device Access Driver (Built TTDA.03.08.874312) rc=0 [ 1.251650] .. rk pwm remotectl v2.0 init [ 1.251989] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input0 [ 1.252538] remotectl-pwm fe6e0030.pwm: pwm version is 0x2130000 [ 1.252585] remotectl-pwm fe6e0030.pwm: cannot find PWR IRQ [ 1.252613] remotectl-pwm fe6e0030.pwm: pwm sip wakeup config error!! [ 1.252628] remotectl-pwm fe6e0030.pwm: Donot support ATF Wakeup [ 1.253592] i2c /dev entries driver [ 1.255300] fan53555-regulator 0-001c: Failed to get chip ID! [ 1.256946] rk808 0-0020: chip id: 0x8090 [ 1.257024] rk808 0-0020: No cache defaults, reading back from HW [ 1.280822] rk808 0-0020: source: on=0x10, off=0x00 [ 1.280861] rk808 0-0020: support dcdc3 fb mode:-22, 63 [ 1.280882] rk808 0-0020: support pmic reset mode:0,0 [ 1.287394] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 1.287457] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 1.287942] vdd_logic: supplied by vcc3v3_sys [ 1.288860] vdd_gpu: supplied by vcc3v3_sys [ 1.289392] vcc_ddr: supplied by vcc3v3_sys [ 1.289889] vdd_npu: supplied by vcc3v3_sys [ 1.290767] vcc_1v8: supplied by vcc3v3_sys [ 1.291237] vdda0v9_image: supplied by vcc3v3_sys [ 1.292061] vdda_0v9: supplied by vcc3v3_sys [ 1.292581] vdda0v9_pmu: supplied by vcc3v3_sys [ 1.293018] vccio_acodec: supplied by vcc3v3_sys [ 1.293857] vccio_sd: supplied by vcc3v3_sys [ 1.294337] vcc3v3_pmu: supplied by vcc3v3_sys [ 1.295177] vcca_1v8: supplied by vcc3v3_sys [ 1.295671] vcca1v8_pmu: supplied by vcc3v3_sys [ 1.296184] vcca1v8_image: supplied by vcc3v3_sys [ 1.297006] vcc_3v3: supplied by vcc3v3_sys [ 1.297799] vcc3v3_sd: supplied by vcc3v3_sys [ 1.298412] rk817-battery rk817-battery: Failed to find matching dt id [ 1.298770] rk817-charger rk817-charger: Failed to find matching dt id [ 1.302311] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input1 [ 1.303000] rk808-rtc rk808-rtc: device is disabled [ 1.303045] rk808-rtc: probe of rk808-rtc failed with error -22 [ 1.304557] fusb302 0-0022: Can't get property of role, set role to default DRP [ 1.308253] fusb302 0-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE [ 1.308484] input: Typec_Headphone as /devices/platform/fdd40000.i2c/i2c-0/0-0022/input/input2 [ 1.310327] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator [ 1.310435] pca953x 1-0021: Linked as a consumer to regulator.0 [ 1.310653] pca953x 1-0021: failed reading register [ 1.310738] pca953x 1-0021: Dropping the link to regulator.0 [ 1.401004] rtc-hym8563 5-0051: could not init device, -6 [ 1.401316] gsensor_mc3230 5-004c: sensor_register_device: gs_mc3230, id = 27 [ 1.401353] i2c i2c-5: sensor_probe: gs_mc3230,00000000647e49f7 [ 1.401427] gsensor_mc3230 5-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0x000000002e148fa3 [ 2.091022] [Gsensor] init_3230_ctl_data 457 : error: -6 [ 2.091056] gsensor_mc3230 5-004c: sensor_initial:fail to init sensor [ 2.091071] gsensor_mc3230 5-004c: sensor_chip_init:fail to init sensor [ 2.091088] i2c i2c-5: sensor_probe failed -2 [ 2.091088] [ 2.094959] iommu: Adding device fdff0000.rkisp to group 7 [ 2.095022] rkisp_hw fdff0000.rkisp: Linked as a consumer to fdff1a00.iommu [ 2.095287] rkisp_hw fdff0000.rkisp: is_thunderboot: 0 [ 2.095310] rkisp_hw fdff0000.rkisp: max input:0x0@0fps [ 2.095362] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff] [ 2.096646] rkisp rkisp-vir0: rkisp driver version: v01.07.00 [ 2.096780] rkisp rkisp-vir0: No memory-region-thunderboot specified [ 2.097056] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized! [ 2.097088] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized! [ 2.099850] usbcore: registered new interface driver uvcvideo [ 2.099883] USB Video Class driver (1.1.1) [ 2.100277] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.26 [ 2.100344] rockchip-iodomain fdc20000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_pmu [ 2.100520] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc3v3_pmu [ 2.100669] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.24 [ 2.100729] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3300000 uV) supplied by vccio_acodec [ 2.100930] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.25 [ 2.100989] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd [ 2.101145] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.20 [ 2.101204] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8 [ 2.101349] rockchip-iodomain fdc20000.syscon:io-domains: Linked as a consumer to regulator.30 [ 2.101398] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3 [ 2.101556] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8 [ 2.101742] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3 [ 2.106124] rockchip-thermal fe710000.tsadc: tsadc is probed successfully! [ 2.107669] Bluetooth: HCI UART driver ver 2.3 [ 2.107704] Bluetooth: HCI UART protocol H4 registered [ 2.107727] Bluetooth: HCI UART protocol ATH3K registered [ 2.108026] Bluetooth: HCI UART protocol Broadcom registered [ 2.108150] usbcore: registered new interface driver bfusb [ 2.108255] usbcore: registered new interface driver btusb [ 2.108632] cpu cpu0: leakage=19 [ 2.108712] cpu cpu0: pvtm = 83550, from nvmem [ 2.108749] cpu cpu0: pvtm-volt-sel=1 [ 2.110990] sdhci: Secure Digital Host Controller Interface driver [ 2.111023] sdhci: Copyright(c) Pierre Ossman [ 2.111043] Synopsys Designware Multimedia Card Interface Driver [ 2.112435] dwmmc_rockchip fe000000.dwmmc: IDMAC supports 32-bit address mode. [ 2.112742] dwmmc_rockchip fe000000.dwmmc: Using internal DMA controller. [ 2.112780] dwmmc_rockchip fe000000.dwmmc: Version ID is 270a [ 2.112882] dwmmc_rockchip fe000000.dwmmc: DW MMC controller at irq 42,32 bit host data width,256 deep fifo [ 2.113109] dwmmc_rockchip fe000000.dwmmc: allocated mmc-pwrseq [ 2.113145] mmc_host mmc3: card is non-removable. [ 2.232928] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.246507] dwmmc_rockchip fe2b0000.dwmmc: IDMAC supports 32-bit address mode. [ 2.246697] dwmmc_rockchip fe2b0000.dwmmc: Using internal DMA controller. [ 2.246732] dwmmc_rockchip fe2b0000.dwmmc: Version ID is 270a [ 2.246852] dwmmc_rockchip fe2b0000.dwmmc: DW MMC controller at irq 50,32 bit host data width,256 deep fifo [ 2.247068] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.31 [ 2.247180] dwmmc_rockchip fe2b0000.dwmmc: Linked as a consumer to regulator.25 [ 2.256970] mmc3 mmc_send_io_op_cond err: -110 [ 2.259724] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.273028] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.274792] mmc0: Unknown controller version (5). You may experience problems. [ 2.306671] mmc0: SDHCI controller on fe310000.sdhci [fe310000.sdhci] using ADMA [ 2.309431] hidraw: raw HID events driver (C) Jiri Kosina [ 2.310034] usbcore: registered new interface driver usbhid [ 2.310065] usbhid: USB HID core driver [ 2.310614] rockchip,bus bus-npu: Linked as a consumer to regulator.16 [ 2.310660] rockchip,bus bus-npu: Failed to get leakage [ 2.310741] rockchip,bus bus-npu: pvtm = 83550, from nvmem [ 2.310781] rockchip,bus bus-npu: pvtm-volt-sel=1 [ 2.311088] rockchip,bus bus-npu: avs=0 [ 2.314730] rockchip-saradc fe720000.saradc: Linked as a consumer to regulator.27 [ 2.315885] rksfc_base v1.1 2016-01-08 [ 2.316953] rksfc fe300000.sfc: rksfc_probe clk rate = 50000000 [ 2.317050] rkflash_dev_init enter [ 2.317088] sfc nor id: ef 60 19 [ 2.317127] rkflash[1] init success [ 2.318781] sfc_nor_mtd_init register mtd succuss [ 2.318814] rkflash_dev_init device register as mtd dev, ret= 0 [ 2.320070] usbcore: registered new interface driver snd-usb-audio [ 2.323455] rk817-codec rk817-codec: DMA mask not set [ 2.324457] rk817_codec_parse_dt_property: rk809 hp adc effective value of detection 976~1024 [ 2.324502] invalid rk817->hp_det_gpio: -2 [ 2.324524] invalid gpio: -2 [ 2.333550] Initializing XFRM netlink socket [ 2.334229] NET: Registered protocol family 10 [ 2.335486] Segment Routing with IPv6 [ 2.335643] NET: Registered protocol family 17 [ 2.335753] NET: Registered protocol family 15 [ 2.335822] can: controller area network core (rev 20170425 abi 9) [ 2.336041] NET: Registered protocol family 29 [ 2.336095] can: raw protocol (rev 20170425) [ 2.336113] can: broadcast manager protocol (rev 20170425 t) [ 2.336137] can: netlink gateway (rev 20170425) max_hops=1 [ 2.336525] Bluetooth: RFCOMM socket layer initialized [ 2.336589] Bluetooth: RFCOMM ver 1.11 [ 2.336615] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.336660] Bluetooth: HIDP socket layer initialized [ 2.336721] [BT_RFKILL]: Enter rfkill_rk_init [ 2.336744] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 2.337517] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 2.337604] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275s [ 2.337631] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 2.337651] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 2.337722] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 124, flags = 0. [ 2.337755] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found ! [ 2.337777] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 2.337799] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1 [ 2.337819] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 2.338675] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 73. [ 2.338739] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 96. [ 2.338781] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 97. [ 2.338820] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 98. [ 2.338933] [BT_RFKILL]: Request irq for bt wakeup host [ 2.339129] [BT_RFKILL]: ** disable irq [ 2.339336] [BT_RFKILL]: bt_default device registered. [ 2.339552] Key type dns_resolver registered [ 2.340223] flash vendor_init_thread! [ 2.340253] flash vendor storage:20170308 ret = -1 [ 2.340974] mmc0: new HS200 MMC card at address 0001 [ 2.342173] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB [ 2.343148] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB [ 2.343903] Loading compiled-in X.509 certificates [ 2.344010] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB [ 2.344262] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB, chardev (239:0) [ 2.344907] pstore: Using compression: deflate [ 2.346329] rga2: Driver loaded successfully ver:3.2.63318 [ 2.346819] rga2: Module initialized. [ 2.349311] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 [ 2.375918] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 300000Hz, actual 187500HZ div = 1) [ 2.388571] phy phy-fe8a0000.usb2-phy.6: Linked as a consumer to regulator.4 [ 2.389005] phy phy-fe8a0000.usb2-phy.7: No vbus specified for otg port [ 2.391579] mali fde60000.gpu: Kernel DDK version g7p1-01bet0 [ 2.391628] dwc3 fcc00000.dwc3: Failed to get clk 'ref': -2 [ 2.391868] mali fde60000.gpu: Linked as a consumer to regulator.17 [ 2.392140] mali fde60000.gpu: dev_pm_opp_set_regulators: no regulator (shadercores) found: -19 [ 2.392284] mali fde60000.gpu: leakage=6 [ 2.392430] mali fde60000.gpu: pvtm = 83550, from nvmem [ 2.392704] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) [ 2.393194] mali fde60000.gpu: avs=0 [ 2.393238] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 112; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available. [ 2.393708] mali fde60000.gpu: GPU identified as 0x2 arch 7.4.0 r1p0 status 0 [ 2.393861] mali fde60000.gpu: No priority control manager is configured [ 2.393896] mali fde60000.gpu: No memory group manager is configured [ 2.394728] mali fde60000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0 [ 2.395938] mali fde60000.gpu: Probed as mali0 [ 2.397914] dwc3 fd000000.dwc3: Failed to get clk 'ref': -2 [ 2.401532] mmc3 mmc_send_io_op_cond err: -110 [ 2.402262] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller [ 2.402671] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 5 [ 2.403506] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000011002010010 [ 2.403614] xhci-hcd xhci-hcd.4.auto: irq 82, io mem 0xfd000000 [ 2.404091] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 2.404114] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.404143] usb usb5: Product: xHCI Host Controller [ 2.404167] usb usb5: Manufacturer: Linux 4.19.206 xhci-hcd [ 2.404190] usb usb5: SerialNumber: xhci-hcd.4.auto [ 2.404965] hub 5-0:1.0: USB hub found [ 2.405043] hub 5-0:1.0: 1 port detected [ 2.405554] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller [ 2.405972] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 6 [ 2.406022] xhci-hcd xhci-hcd.4.auto: Host supports USB 3.0 SuperSpeed [ 2.406153] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.406366] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 2.406400] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.406427] usb usb6: Product: xHCI Host Controller [ 2.406452] usb usb6: Manufacturer: Linux 4.19.206 xhci-hcd [ 2.406475] usb usb6: SerialNumber: xhci-hcd.4.auto [ 2.407232] hub 6-0:1.0: USB hub found [ 2.407318] hub 6-0:1.0: 1 port detected [ 2.408515] input: adc-keys as /devices/platform/adc-keys/input/input3 [ 2.410659] asoc-simple-card hdmi-sound: i2s-hifi <-> fe400000.i2s mapping ok [ 2.419428] asoc-simple-card rk809-sound: rk817-hifi <-> fe410000.i2s mapping ok [ 2.419486] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1 [ 2.419505] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack [ 2.419521] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P [ 2.419545] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P [ 2.419569] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL [ 2.419590] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack [ 2.419615] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR [ 2.419638] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack [ 2.424478] register spi return v = :0 [ 2.424517] dhd_module_init: in Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8) [ 2.424540] ======== dhd_wlan_init_plat_data ======== [ 2.424561] [W
[ 2.519201] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 200000Hz, actual 187500HZ div = 1) [ 2.535896] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) [ 2.545014] mmc3 mmc_send_io_op_cond err: -110 [ 2.662488] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 100000Hz, actual 93750HZ div = 2) [ 2.683059] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) [ 2.692191] mmc3 mmc_send_io_op_cond err: -110 [ 2.729205] wifi_platform_bus_enumerate device present 1 [ 2.729239] ======== Card detection to detect SDIO card! ======== [ 2.729253] mmc3:mmc host rescan start! [ 3.627915] phy phy-fe8a0000.usb2-phy.7: charger = USB_SDP_CHARGER [ 4.752524] failed to power up DHD generic adapter, 0 retry left [ 4.768709] wifi_platform_set_power = 0, delay: 0 msec [ 4.768742] ======== PULL WL_REG_ON(-1) LOW! ======== [ 4.768756] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 4.768775] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false [ 4.768788] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1] [ 4.768798] wifi_platform_bus_enumerate device present 0 [ 4.768809] ======== Card detection to remove SDIO card! ======== [ 4.768820] mmc3:mmc host rescan start! [ 4.768831] failed to power up DHD generic adapter, max retry reached** [ 4.768845] unregister wifi platform drivers [ 4.768868] wifi_platform_bus_enumerate device present 0 [ 4.768890] ======== Card detection to remove SDIO card! ======== [ 4.768907] mmc3:mmc host rescan start! [ 4.768925] ======== dhd_wlan_deinit_plat_data ======== [ 4.768946] dhd_module_init: Failed to load the driver, try cnt 0 [ 4.769059] dhd_module_init: Failed to load driver max retry reached** [ 4.769076] dhd_module_init: Exit err=-19 [ 4.769676] ==gsl_ts_init== [ 4.769797] ret=0 [ 4.771451] iommu: Adding device fde40000.npu to group 0 [ 4.771513] RKNPU fde40000.npu: Linked as a consumer to fde4b000.iommu [ 4.772189] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode [ 4.772469] RKNPU fde40000.npu: Linked as a consumer to regulator.19 [ 4.772518] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff] [ 4.773446] [drm] Initialized rknpu 0.4.2 20210701 for fde40000.npu on minor 1 [ 4.773888] RKNPU fde40000.npu: leakage=3 [ 4.773952] RKNPU fde40000.npu: pvtm = 83550, from nvmem [ 4.774836] RKNPU fde40000.npu: avs=0 [ 4.775685] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0 [ 4.775775] RKNPU fde40000.npu: failed to find power_model node [ 4.775806] RKNPU fde40000.npu: RKNPU: failed to initialize power model [ 4.775832] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient [ 4.777859] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 4.784632] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 4.784830] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2 [ 4.784863] cfg80211: failed to load regulatory.db [ 4.786277] rockchip-pm rockchip-suspend: not set pwm-regulator-config [ 4.788726] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '19:43:40', on 'Jan 7 2022'. [ 4.789395] Mali: [ 4.789398] Mali device driver loaded [ 4.789788] xc7160 4-001b: T-chip firefly camera driver version: 00.01.02 [ 4.790160] xc7160 4-001b: Failed to get power-gpios, maybe no use [ 4.790344] xc7160 4-001b: 4-001b supply avdd not found, using dummy regulator [ 4.790467] xc7160 4-001b: Linked as a consumer to regulator.0 [ 4.790545] xc7160 4-001b: 4-001b supply dovdd not found, using dummy regulator [ 4.790694] xc7160 4-001b: 4-001b supply dvdd not found, using dummy regulator [ 4.790788] xc7160 4-001b: could not get default pinstate [ 4.790819] xc7160 4-001b: could not get sleep pinstate [ 4.790852] xc7160 4-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes [ 4.790877] xc7160 4-001b: xc7160 num data lanes is 4 [ 5.819141] rk3x-i2c fe5d0000.i2c: timeout, ipd: 0x00, state: 2 [ 5.819183] xc7160 4-001b: write XC7160_REG_HIGH_SELECT failed [ 5.819534] xc7160: probe of 4-001b failed with error -5 [ 5.819652] rkisp rkisp-vir0: clear unready subdev num: 4 [ 5.819683] rockchip-csi2-dphy0: No link between dphy and sensor [ 5.820505] rockchip-csi2-dphy0: No link between dphy and sensor [ 5.820535] rkisp-vir0: update sensor failed v⚌ 5.824608] |
7个回答
补充:
1. 使用编译出的image,在自己做的板子上,用SD卡能够正常启动; 2.跟踪启动过程,发现启动流程卡在了mdev_misc_init中;但是这个函数搜遍了kernel没找到; |
使用官方最新固件做卡工具用 SDDiskTool_v1.7
用了最新的固件(ROC-RK3568-PC-UBUNTU18.04-GPT-20220222-1540.img)烧录emmc,还是不行,还是一样的现象,内核启动之后,一直卡在rkisp-vir0: update sensor failed
确认是用的 ROC-RK3568-PC 板子吗?有没有试过 Android 固件?
什么原因啊, 我们也碰到了类似的问题
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1285 浏览 1 评论
RK3568平台,进入烧录模式,部分电脑提示无法识别,无法烧录
4306 浏览 1 评论
【RK3568 Android11.0】如何在设置-显示-HDMI-分辨率设置中添加3840*2160的选项?
6896 浏览 1 评论
瑞芯微第二代8nm高性能AIOT平台 RK3576 详细介绍
1710 浏览 0 评论
7147 浏览 1 评论
GMT+8, 2024-5-9 17:03 , Processed in 0.793218 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
