用Cube生成的RTC初始化会进入超时
HAL_StatusTypeDef RTC_EnterInitMode(RTC_HandleTypeDef *hrtc) { uint32_t tickstart = 0U; /* Check if the Initialization mode is set */ if ((hrtc->Instance->ISR RTC_ISR_INITF) == (uint32_t)RESET) { /* Set the Initialization mode */ hrtc->Instance->ISR = (uint32_t)RTC_INIT_MASK; tickstart = HAL_GetTick(); /* Wait till RTC is in INIT state and if Time out is reached exit */ while ((hrtc->Instance->ISR RTC_ISR_INITF) == (uint32_t)RESET) { if ((HAL_GetTick() - tickstart) > RTC_TIMEOUT_VALUE) { return HAL_TIMEOUT; } } } return HAL_OK; } 生成的代码如下 /* RTC init function */ void MX_RTC_Init(void) { RTC_TimeTypeDef sTime = {0}; RTC_DateTypeDef sDate = {0}; RTC_AlarmTypeDef sAlarm = {0}; /** Initialize RTC Only */ hrtc.Instance = RTC; hrtc.Init.HourFormat = RTC_HOURFORMAT_24; hrtc.Init.AsynchPrediv = 127; hrtc.Init.SynchPrediv = 255; hrtc.Init.OutPut = RTC_OUTPUT_DISABLE; hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH; hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN; if (HAL_RTC_Init( hrtc) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN Check_RTC_BKUP */ /* USER CODE END Check_RTC_BKUP */ /** Initialize RTC and set the Time and Date */ sTime.Hours = 0x0; sTime.Minutes = 0x0; sTime.Seconds = 0x0; sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE; sTime.StoreOperation = RTC_STOREOPERATION_RESET; if (HAL_RTC_SetTime( hrtc, sTime, RTC_FORMAT_BCD) != HAL_OK) { Error_Handler(); } sDate.WeekDay = RTC_WEEKDAY_MONDAY; sDate.Month = RTC_MONTH_JANUARY; sDate.Date = 0x1; sDate.Year = 0x0; if (HAL_RTC_SetDate( hrtc, sDate, RTC_FORMAT_BCD) != HAL_OK) { Error_Handler(); } /** Enable the Alarm A */ sAlarm.AlarmTime.Hours = 0x0; sAlarm.AlarmTime.Minutes = 0x0; sAlarm.AlarmTime.Seconds = 0x0; sAlarm.AlarmTime.SubSeconds = 0x0; sAlarm.AlarmTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE; sAlarm.AlarmTime.StoreOperation = RTC_STOREOPERATION_RESET; sAlarm.AlarmMask = RTC_ALARMMASK_NONE; sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_ALL; sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE; sAlarm.AlarmDateWeekDay = 0x1; sAlarm.Alarm = RTC_ALARM_A; if (HAL_RTC_SetAlarm_IT( hrtc, sAlarm, RTC_FORMAT_BCD) != HAL_OK) { Error_Handler(); } } void HAL_RTC_MspInit(RTC_HandleTypeDef* rtcHandle) { if(rtcHandle->Instance==RTC) { /* USER CODE BEGIN RTC_MspInit 0 */ /* USER CODE END RTC_MspInit 0 */ /* RTC clock enable */ __HAL_RCC_RTC_ENABLE(); /* RTC interrupt Init */ HAL_NVIC_SetPriority(RTC_IRQn, 0, 0); HAL_NVIC_EnableIRQ(RTC_IRQn); /* USER CODE BEGIN RTC_MspInit 1 */ /* USER CODE END RTC_MspInit 1 */ } } void HAL_RTC_MspDeInit(RTC_HandleTypeDef* rtcHandle) { if(rtcHandle->Instance==RTC) { /* USER CODE BEGIN RTC_MspDeInit 0 */ /* USER CODE END RTC_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_RTC_DISABLE(); /* RTC interrupt Deinit */ HAL_NVIC_DisableIRQ(RTC_IRQn); /* USER CODE BEGIN RTC_MspDeInit 1 */ /* USER CODE END RTC_MspDeInit 1 */ } } /* USE void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInit = {0}; /** Initializes the CPU, AHB and APB busses clocks */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE; RCC_OscInitStruct.HSEState = RCC_HSE_ON; RCC_OscInitStruct.LSIState = RCC_LSI_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6; RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1; if (HAL_RCC_OscConfig( RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /** Initializes the CPU, AHB and APB busses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig( RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK) { Error_Handler(); } PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC; PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI; if (HAL_RCCEx_PeriphCLKConfig( PeriphClkInit) != HAL_OK) { Error_Handler(); } } /* USER CODE BEGIN 4 */ /* USER CODE END 4 */ /** * @brief This function is executed in case of error occurrence. * @retval None */ void Error_Handler(void) { /* USER CODE BEGIN Error_Handler_Debug */ /* User can add his own implementation to report the HAL error return state */ /* USER CODE END Error_Handler_Debug */ } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t *file, uint32_t line) { /* USER CODE BEGIN 6 */ /* User can add his own implementation to report the file name and line number, tex: printf("Wrong parameters value: file %s on line %drn", file, line) */ /* USER CODE END 6 */ } #endif /* USE_FULL_ASSERT */ /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/ 不知道是怎么回事 |
1个回答
RTC初始化进入超时的原因可能有以下几个:
1. RTC外设故障:检查RTC外设是否正常工作,是否连接正确。 2. RTC时钟源选择错误:检查RTC时钟源的配置是否正确,例如使用外部时钟而未正确配置。 3. RTC预分频值设置错误:检查RTC预分频值的配置是否正确,例如将预分频设置为0或设置了错误的值。 4. 中断使能配置错误:检查是否正确配置了RTC的初始化中断使能。 5. HAL库函数调用错误:检查是否正确调用了HAL库函数,例如未正确初始化RTC_HandleTypeDef结构体。 6. 硬件问题:检查RTC外设相关引脚的连接是否稳定,例如是否有松动或焊接问题。 以上是一些可能导致RTC初始化进入超时的原因,具体问题需要根据实际情况进行排查和调试。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
694 浏览 0 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
457 浏览 1 评论
296 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
259 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
626 浏览 2 评论
1392浏览 9评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
89浏览 3评论
46浏览 3评论
STM32CUBEMX4.22.1在main函数里面添加一行语句就死机的原因?
59浏览 3评论
52浏览 3评论
GMT+8, 2024-5-6 21:27 , Processed in 0.633523 second(s), Total 47, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
